[Dev] Home Assistant OS - Khadas Vim1
I have build Hass OS from Agners dev repo for Khadas Vim1 Device.
It is using Odroid C2 as host config’s though.
Works perfectly fine on my device. I have migrated my RPI3B+ setup to Khadas Vim1 which I had build for a small setup but as the setup is becoming big, vim1 is very stable and working as expected.
I have already published it in Khadas forum but thought I’d post it here to make more users aware of this.
Khadas Forum Link
Hass OS Source
Download HA-OS-Vim1-Dev-7.0-2021-09-19
All credit goes to Agner and HA team.
Bonjour
Je viens d’installer la dernière image de home assistant mais je ne sais pas comment ajouter les addons. je pense qu’il faut les gérer au travers de containers mais je n’ai pas la connexion en ssh avec putty.
Hi @spikerguy , thank you for your work.
3 years and half later, can you give 5 minutes there to let me know how goo it is/was ? What about the last HA version ? It seems that kernel-6 on Vim1s is still not supported, but on the way to run soon i hope.
Do you still use this device or do you experiment some other around (wich one) ?
Thank you to share your experience with the community, it is awesome.
