I’m really embarrassed to not solve this myself, but my google-fu is failing. I’m certain it’s a simple solve for someone who has been here before but I’m at a loss.
I want to use a script to send notifications to inovelli lights and use a parameter to identify the target. I’m getting the error “No zwave_js nodes found for given target” when I’m trying to run the script, either independently (relying on the default value) or through an automation attempting to pass data parameters.
If I remove the field and hard-code the ID, the script works exactly as expected. So my problem is clearly some syntax, formatting, organization issue with the YAML for the script.
Doesn’t work:
fields:
device_id:
default: ce20880c2045741585f1ef3c41678529
description: Device ID to update notification
sequence:
- service: zwave_js.set_config_parameter
parameter: "99"
value: "255"
bitmask: FF
device_id: "{{ device_id }}"
parameter: "99"
value: "100"
bitmask: FF00
parameter: "99"
value: "128"
bitmask: FF0000
parameter: "99"
value: "2"
bitmask: FF000000
mode: single
Does work:
sequence:
parameter: "99"
value: "255"
bitmask: FF
device_id: ce20880c2045741585f1ef3c41678529
parameter: "99"
value: "100"
bitmask: FF00
parameter: "99"
value: "128"
bitmask: FF0000
parameter: "99"
value: "2"
bitmask: FF000000
mode: single
I’m at sea here, really appreciate any assistance.
