Hi all,
I am a new user of 2 days in Home Assistant. Been watching a lot of tutorials and reading a lot of posts.
My problem is that device_tracker entities are showing as icons on my panels.
I am using Life360. I was using this tutorial
Everything is working correctly, I can see members, zones and tracking are working perfectly.
I have just a problem with the interface. The images that I have set up in Life360 are not coming through.
I tried to change image manually but when I go to the specific track entity I do not have the option to change entity_picture (Configuration > Customization > device_tracker entity edit.
Can someone please help me understand what I am doing wrong.
Thanks in advance.
The picture from the Life360 app is only used the first time a member is seen (when it is added to known_devices.yaml.) If you change the picture in the Life360 app after that it will be ignored. This is a limitation of the device_tracker component level code. If you want the picture to be used you’ll have to remove the entry from known_devices.yaml and restart.
