Device Tracker not working
Hi, I’m having problems with the device tracker.
The known_devices.yaml file was not created
In the log I have the following error:
Error setting up platform mikrotik
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/init.py”, line 177, in async_setup_platform
platform.get_scanner, hass, {DOMAIN: p_config})
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/mikrotik.py”, line 33, in get_scanner
scanner = MikrotikScanner(config[DOMAIN])
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/mikrotik.py”, line 60, in init
self._update_info()
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/mikrotik.py”, line 159, in _update_info
device_names = self.client(cmd=’/ip/dhcp-server/lease/getall’)
File “/usr/local/lib/python3.6/site-packages/librouteros/api.py”, line 80, in call
return self._readResponse()
File “/usr/local/lib/python3.6/site-packages/librouteros/api.py”, line 103, in _readResponse
reply_word, words = self._readSentence()
File “/usr/local/lib/python3.6/site-packages/librouteros/api.py”, line 88, in _readSentence
reply_word, words = self.protocol.readSentence()
File “/usr/local/lib/python3.6/site-packages/librouteros/connections.py”, line 147, in readSentence
sentence = tuple(word for word in iter(self.readWord, b’\x00’))
File “/usr/local/lib/python3.6/site-packages/librouteros/connections.py”, line 164, in readWord
return self.transport.read(length).decode(encoding=self.encoding, errors=‘strict’)
UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0xa0 in position 64: invalid start byte
I need help the problem is too much for me now
