Device tracker state home case sensitive
my first bug report
tracker return home state instead of Home in the automation
Regards
If iPhone_private is Home
Executed: May 19, 2025 at 12:27:42 PM
Result:
result: false
entity_id/0
Result:
result: false state: home wanted_state: Home
entity: device_tracker.iphone
Version core-2025.5.2
Installation type Home Assistant OS
Development false
Supervisor true
Docker true
User root
Virtual environment false
Python version 3.13.3
Operating system family Linux
Operating system version 6.12.23-haos
CPU architecture x86_64
This is not a bug report…
Those go here →
(Be sure to search there to make sure it has not already been reported. If it has, thumbs up the report, don’t add me-too info…)
Reporting issues - Home Assistant.
It’s not a bug - all states are case sensitive in automations.
As far as I know the automation editor helps you with devices with known states.
Did you write the automation by yourself?
Edit: just looked at it, when I make an automation I get presented with all zones I have added.
So… How did you mess that up?
This is correct. “Home” is used in the UI (the devs thought it would be easier, or prettier or something) but in yaml it’s lower case. Same with On and on, Off and off etc. It’s a feature.
