The Goal: Open garage door upon entering Home zone.
Issue: device_tracker.kwcuts_iphone never changes from ‘home’ when I’m away from home.
Locative correctly tracked me.
The HA companion app precisely tracked my locations.
Able to control Home Assistant while I was away through Tailscale.
Yet device_tracker still showed at home.
I don’t know how to proceed. Please HELP. Thank you in advance.
I switched phones a while ago and found that I did not switch which phone’s presence was being used to figure out whether or not I was home. Don’t know if that helps.
Even if you don’t use the integration, here is a very thorough document about every possible nuance to consider to get perfect location tracking (read all #1-20):
