I have been using HA to control my greenhouse for about a year. Just lately it has started triggering my humidifier too often. The humidifier is controlled by a Shelly plus 2 PM and 2 automations (on/off). The other connected device is lights which are working correctly. I have 2 Home Assistant instances running on separate RPi 5s. The automations are all the same. I use the 2 RPis for redundancy. I have unplugged the humidifier for now to try to get things under control, but the automation is still turning the humidifier on. The humidity sensor is a Sensor Push temp/humidity sensor.
Version info:
- Installation method Home Assistant OS
- Core 2026.4.3
- Supervisor 2026.04.0
- Operating System 17.2
- Frontend 20260325.5
I canât find the firmware version info for the Shellyplus2PM device, but it is listed as âup to dateâ by HA.
Here is the YAML for the âonâ automation. The âoffâ automation just triggers on âabove 70â.
description: Turn on the greenhouse humidifier
triggers:
- trigger: numeric_state
entity_id:
- sensor.greenhouse_temp_humidity_humidity
below: 65
conditions:
- condition: state
entity_id: switch.shellyplus1_c4d8d552dcd8_switch_0 <- this is an exhaust fan
state: "off"
actions:
- action: switch.turn_on
metadata: {}
data: {}
entity_id: switch.shellyplus2pm_cc7b5c0e3658_switch_1
mode: single
Here is a snippet of the humidifier history. Most of the times that it is turned off are by me. It has become âunavailableâ a few times recently. My GH heater is tripping the GFCI circuit breaker that this Shelly device is connected to. I think that is due to the excessive humidity causing a ground fault in the heater.
10:06:40 AM - 22 minutes ago - ChuckCrisler
turned on triggered by automation Greenhouse Humidifier on triggered
10:06:23 AM - 22 minutes ago
turned off triggered by action Switch: Turn off switch
10:04:01 AM - 24 minutes ago - ChuckCrisler
8:38:58 AM - 2 hours ago
8:03:51 AM - 2 hours ago - ChuckCrisler
6:25:02 AM - 4 hours ago
turned off
6:23:01 AM - 4 hours ago
became unavailable
2:00:54 AM - 8 hours ago
#### April 17, 2026
11:01:49 PM - 11 hours ago
turned off
9:47:00 PM - 13 hours ago
Here is a snippet of the humidity sensor updates. As you can see the reported humidity hasnât dropped below 85% in several days. That seems accurate because everything is damp in the greenhouse.
sensor.greenhouse_temp_humidity_humidity,85.31,2026-04-18T12:41:24.494Z
sensor.greenhouse_temp_humidity_humidity,85.34,2026-04-18T12:44:24.456Z
sensor.greenhouse_temp_humidity_humidity,85.37,2026-04-18T12:51:20.512Z
sensor.greenhouse_temp_humidity_humidity,85.4,2026-04-18T12:52:23.092Z
sensor.greenhouse_temp_humidity_humidity,85.37,2026-04-18T12:56:21.763Z
sensor.greenhouse_temp_humidity_humidity,85.34,2026-04-18T12:58:23.030Z
sensor.greenhouse_temp_humidity_humidity,85.31,2026-04-18T12:59:25.598Z
sensor.greenhouse_temp_humidity_humidity,85.28,2026-04-18T13:01:20.432Z
sensor.greenhouse_temp_humidity_humidity,85.25,2026-04-18T13:02:29.441Z
sensor.greenhouse_temp_humidity_humidity,85.28,2026-04-18T13:07:20.374Z
sensor.greenhouse_temp_humidity_humidity,85.25,2026-04-18T13:11:22.948Z
sensor.greenhouse_temp_humidity_humidity,85.28,2026-04-18T13:14:22.875Z
sensor.greenhouse_temp_humidity_humidity,85.25,2026-04-18T13:16:24.160Z
sensor.greenhouse_temp_humidity_humidity,85.28,2026-04-18T13:25:21.580Z
sensor.greenhouse_temp_humidity_humidity,85.34,2026-04-18T13:26:20.185Z
sensor.greenhouse_temp_humidity_humidity,85.37,2026-04-18T13:37:22.662Z
sensor.greenhouse_temp_humidity_humidity,85.34,2026-04-18T13:43:22.601Z
sensor.greenhouse_temp_humidity_humidity,85.4,2026-04-18T13:44:25.164Z
sensor.greenhouse_temp_humidity_humidity,85.43,2026-04-18T13:45:27.733Z
sensor.greenhouse_temp_humidity_humidity,85.4,2026-04-18T13:50:22.543Z
sensor.greenhouse_temp_humidity_humidity,85.37,2026-04-18T13:53:22.509Z
sensor.greenhouse_temp_humidity_humidity,85.31,2026-04-18T13:58:23.732Z
