Devices in Zigbee2mqtt don't show up in Home Assistant
I had to reinstall HA on my RPi3. I reinstalled Zigbee2MQTT. I am able to control my devices from it but they don’t show up in HA. I saw a lot of topics on the subject but I cannot find a solution to my problem. I’m using Zigbee2MQTT 2.2.1-1.
The Mosquitto Broker seems to be receiving messages:
[13:48:14] INFO: Successfully send service information to the Supervisor.
2025-04-06 14:18:00: Saving in-memory database to /data//mosquitto.db.
2025-04-06 14:25:33: New connection from 172.30.33.3:46948 on port 1883.
2025-04-06 14:25:33: New client connected from 172.30.33.3:46948 as mqttjs_7554dcc7 (p2, c1, k60, u’addons’).
2025-04-06 14:41:42: Client mqttjs_7554dcc7 disconnected.
2025-04-06 14:42:37: New connection from 172.30.33.3:50084 on port 1883.
2025-04-06 14:42:37: New client connected from 172.30.33.3:50084 as mqttjs_73209a6c (p2, c1, k60, u’addons’).
2025-04-06 14:48:01: Saving in-memory database to /data//mosquitto.db.
2025-04-06 15:01:20: Client mqttjs_73209a6c disconnected.
2025-04-06 15:02:34: New connection from 172.30.33.3:42472 on port 1883.
2025-04-06 15:02:34: New client connected from 172.30.33.3:42472 as mqttjs_49a7b614 (p2, c1, k60, u’addons’).
2025-04-06 15:06:04: Client mqttjs_49a7b614 disconnected.
2025-04-06 15:06:29: New connection from 172.30.33.3:51148 on port 1883.
2025-04-06 15:06:29: New client connected from 172.30.33.3:51148 as mqttjs_4edb50ff (p2, c1, k60, u’addons’).
What should I be looking at to solve this issue?
Hi, if you come from z2m v1.x, things have changed since v2.x.
With v2.x, event based actions are being used instead of the old action sensors.
Check this thread which explains it all: Using the new action events in Zigbee2MQTT 2.0
I do, thanks, I’ll checkout the guide.
