Something wired happened today with my HassIO setup. I had to add a few more Inovelli LZW31 switches. The switches were added, but Z-Wave was unresponsive. The lights wouldn’t go on or off. I restarted HomeAssistant from the server control page. When it came back on Z-Wave stated to work but a lot of device names are not updated in the Devices tab under configuration page. However, when I open the device, it is named correctly. No exactly sure what happened, but how do I fix this? When I create a new automation it shows the genetic name of the devices.
I am using an openzwave setup. In my configuration.yaml I have
zwave:
usb_path: /dev/ttyACM0
config_path: /config/openzwave/config/
