Hi, thanks for your example.
is it possible to add the device id and/or name to the array?
I would like to get an array of device with name/id and a entity array for each device.
Currently I’m reading entities with Websocket API. But I search for a way to get the devices and their entities to group teh entities.
Many thanks
Edit. I think I got it. Here is the result for anyone serching something similar:
{% set devices = states | map(attribute='entity_id') | map('device_id') | unique | reject('eq',None) | list %}
{%- set ns = namespace(devices = []) %}
{%- for device in devices %}
{%- set entities = device_entities(device) | list %}
{%- if entities %}
{%- set ns.devices = ns.devices + [ {device: {"name": device_attr(device, "name"), "entities":[entities ]}} ] %}
{%- endif %}
{%- endfor %}
{{ ns.devices }}
Result:
"b1958109af6746099296912d0bbb9860": {
"name": "Bew.Sensor Flur",
"entities": [
"sensor.bew_sensor_flur_temperature",
"sensor.bew_sensor_flur_light_level",
"binary_sensor.bew_sensor_flur_motion",
"sensor.bew_sensor_flur_battery",
"switch.bew_sensor_flur_motion",
"switch.bew_sensor_flur_illuminance"
