Devolo Keyfob Single Press
I made the following blueprint in order to set actions on Devolo Smart Home Key Fob Switch 4 buttons. On listening events on developer mode figured out that in any way I press the 4 buttons (including double press, triple press hold/release) It only listened the same ID as single press. So it works with single presses only.
Hope someone with better programming skills make it better than it is.
Open your Home Assistant instance and show the blueprint import dialog with a specific blueprint URL.
