Dewenwils integration
Any way to integrate a pool switch into HA?
Hello Steve,
What have you done so far? How to help us help you - or How to ask a good question
I’m sure that can be done. Also having someone or something writing it for you means the second it misbehaves, you will be struggling back to find someone to fix it for you.
The best way to learn is to just try. Run thru the docs on getting started with the automation editor. If you get stuck, come back with what you have done.
Understanding automations - Home Assistant
and
The Home Assistant Cookbook - Index.
Trying find a way to add device into HA. No luck yet. Will try to find a switch that has support
Although I have no idea if true or not, I'd kinda be surprised if that wasn't Tuya under the hood... Have you tried seeing if it shows up under a local-tuya integration?
I don't use any Tuya stuff myself (so no direct experience), but IIRC, there's more than one local-tuya integration along those lines...
I just found the Tuya local option. I will try that. The Tuya and Smart Home did not. Thanks!
No go on this...
I don’t mind installing a new switch. Anyone using a 40A 240v switch in HA? Need to buy one that works with HA. Thanks!
I use a Shelly controller between the breaker box and the equipment (before all boxes and fuse). No manual control (fyi)… The only way I found to turn it off manually when the Shelly is on… Is to… Remove the fuse… Service the pool, reconnect, done
Hope it helps
