Juergen
(Juergen)
November 16, 2016, 9:14am
1
16-11-16 08:54:55 homeassistant.util.yaml: mapping values are not allowed here
in “/home/hass/.homeassistant/configuration.yaml”, line 85, column 15
is what I do see in my log file.
my yaml looks like and line 85 is the “sensor: DHT22” line:
platform: yr
platform: dht
sensor: DHT22
pin: 04
monitored_conditions:
- temperature
- humidity
BertrumUK
(Neil B)
November 16, 2016, 9:39am
2
Remove “platform: yr” from your config - that is for the weather.
silvrr
November 16, 2016, 1:34pm
3
Can you repost your config. After you paste it in highlight it and hit the < \ > button just above where you type.
This will let the spacing/formatting display correctly so it can be checked. This may just be a spacing issue.
Also try putting the dht22 in lowercase letters. Sometimes HA doesn’t like capital letters.
BertrumUK
(Neil B)
November 16, 2016, 2:39pm
4
This is my working config for an AM2302 sensor
sensor 11:
platform: dht
sensor: AM2302
pin: 23
- temperature
- humidity
Juergen
(Juergen)
November 16, 2016, 6:17pm
5
I have a
platform: dht
sensor: DHT22
pin: 04
- temperature
- humidity
and nothing on the screen and the log is empfy on that topic
silvrr
November 16, 2016, 6:22pm
6
Did you double check your wiring? Is your data wire plugged into GPIO 4 (not pin 4).
Also, have you given your HA user access to the GPIO?
Im assuming your on a PI…
If you used the all in one installer, run the command
sudo adduser hass gpio
If you used the hassbian image, run the command
sudo adduser homeasisstant gpio
The above adds your applicable HA user to use the GPIO pins. By default user Pi has access but the HA user (hass or homeassistant) does not.
Juergen
(Juergen)
November 16, 2016, 6:28pm
7
Thanks for your replay.
I will try to query the DHT tomorrow from the cli.
THE GPIO Pin is what I have used on the PI 3.
The sudo adduser hass gpio ran yesterdasy
Si I think either the pic with the GPIO pin from PI3 is wrong or the sensor is dead
silvrr
November 16, 2016, 6:35pm
8
So you have the data wire (2nd pin from the left on your sensor) going to GPIO 4 (pin 7)?
In addition as I have asked in both threads please post your config and maintain formatting. It is so important in HA to be able to check the formatting.
- platform: dht
sensor: DHT22
pin: '04'
- temperature
- humidity
Have you tried changing the 04 to ‘04’ ?
Juergen
(Juergen)
November 16, 2016, 6:41pm
9
Tried both. Not really changing.
Juergen
(Juergen)
November 16, 2016, 7:01pm
10
So the error seems to be consistent
sudo ./AdafruitDHT.py 22 4
Failed to get reading. Try again!
Another Sensor -> Same result.
I will walk to another PI and see if this is still the problem there.
Juergen
(Juergen)
November 16, 2016, 7:28pm
11
So on the Commandline with PIN22 I got results from the 3rd DHT22
Let’s see how Home Assistant will look like
Juergen
(Juergen)
November 16, 2016, 7:37pm
12
nope
No result reported in the GUI.
How ofter is Home Assistant doing a read on the sensor?
Can I trigger that to do it every minute?
Juergen
(Juergen)
November 16, 2016, 7:40pm
13
I do see
]: 16-11-16 19:38:58 INFO (MainThread) [homeassistant.loader] Loaded sensor.dht from homeassistant.components.sensor.dht
Juergen
(Juergen)
November 17, 2016, 8:03am
17
Today in the morning the logfile stats:
16-11-17 07:45:30 homeassistant.components.sensor.dht: DHT sensor type is not supported
the config looks like
Weather Prediction
platform: yr
platform: dht
sensor: dht22
pin: ‘22’
Juergen
(Juergen)
November 17, 2016, 11:11am
19
Folks,
I tried a
platform: DHT
sensor: dht22
pin: ‘22’
-> 16-11-17 11:04:44 homeassistant.components.sensor.dht: DHT sensor type is not supported
platform: dht
sensor: dht22
pin: ‘22’
temperature
humidity
-> 16-11-17 11:04:44 homeassistant.components.sensor.dht: dht sensor type is not supported
BertrumUK
(Neil B)
November 17, 2016, 11:43am
20
Do you have a pull up resister between the 3.3 V line and the data line ?
Juergen
(Juergen)
November 17, 2016, 4:57pm
21
I mean I can get a result when I use
sudo ./AdafruitDHT.py 22 22
Temp=25.1* Humidity=61.4%
so it should be configured in the right manner?
Do not get it why
platform: DHT
sensor: dht22
pin: ‘22’
does not work???
Juergen
(Juergen)
November 17, 2016, 9:24pm
22
Removed the resistor with a new one and a new sensor and things are working. I will also try with upper case DHC to see if this changes the behavior.
THANKS for your help
