Dial to control PD-Stepper
Hi
I have connected a PD-Stepper to HA, and am using the code
PD-Stepper-Position-Control.yaml from GitHub.
https://github.com/joshr120/PD-Stepper/blob/870a41527dd028ad13010b296cfe6356db55e7e9/Software/ESPHome/PD-Stepper-Position-Control.yaml
So far so good. I can control position.
This will be my first YAML project.
I want to end up with a dial on my dashboard, with the numbers 0-9 around it, that will move the stepper motor to a particular numerical position for each number when clicked. For simplicity let’s say that each number is one rotation, or 200 steps. So if I click the number one, it will go to 200 (1 times 200 steps), 5 will give 1000 (5 times 200 steps).
Can someone point me to the right way to do this? Not sure what change in the YAML - if any, because there is a section in the YAML that will send it to a particular position (code below)
also don’t know what card to start with to implement this well
Can anyone point me toward the right direction?
number:
    min_value: -10000
    max_value: 10000
    step: 100
    lambda: return id(driver)->current_position;
    update_interval: 1s
    set_action:
      - stepper.set_target:
          target: !lambda "return x;"
Hi, sorry but I cannot help you.
I’m curious though what/how you are using this: do you mind sharing that?
I’m using this to control a propane furnace that has a control dial, but no thermostat, or any electrical smarts (probably 60 years old). I got the PD Stepper mounted on a stepper motor, added a pulley for a small timing belt, and another pulley on the square shaft of the control knob. When not moving, the motor freewheels so you use the knob normally, but now i can adjust the furnace when I am away.
I travel a lot, sometimes for 1-2 months, and if it is winter, there is risk of pipes freezing. So I want to be able to control the heat. I also want to conserve the propane, as you cannot get a delivery of propane here from about December and May due to winter.
I have this fully operational now, I signed up for Claude Code, as I figured it would be quicker than learning how to code it on my own. It worked, after many, many iterations.
