nikla
(Niklas)
February 27, 2022, 7:44pm
1
I have one temperature sensor from modbus integration and two sensors from mqtt integration. I would like to have all three in the same histogram graph. Today it looks like this:
The modbus sensor is defined like this:
- name: Nibe
type: tcp
host: <local IP>
port: 502
sensors:
- name: "Utetemperatur (BT1)"
device_class: temperature
state_class: measurement
address: 1
count: 1
slave: 1
precision: 1
input_type: input
scale: 0.1
scan_interval: 60
The two other sensors are defined like this:
- platform: mqtt
state_topic: "Byvallen/28.E99295040000"
unique_id: temperature.uterum
device_class: "temperature"
value_template: "{{ value_json.temperature }}"
force_update: true
- platform: mqtt
state_topic: "Byvallen/28.78F52F040000"
unique_id: temperature.vathus2
force_update: true
I assume that I have missed something but I donât understand why they donât end up in the same graph.
Edit: when I hover of the lower graph I realize that I donât have any unit for the measurement. Can that be the problem? I thought I got C by default for all temperature sensors.
Iâm running 2022.2.9 of HA on Home Assistant Blue.
tom_l
February 28, 2022, 2:30am
2
Yes that is the problem.
You need to give the utetemperatur_bt1
sensor a unit_of_measurement: "°C"
nikla
(Niklas)
March 1, 2022, 8:59pm
3
I still fail. My config is now
- name: Nibe
type: tcp
host: <local ip>
port: 502
sensors:
address: 1
count: 1
slave: 1
precision: 1
input_type: input
scale: 0.1
scan_interval: 60
I still do not see °C as the unit while hover over the graph.
The sensor is using the modbus integration. Can that be the problem?
nikla
(Niklas)
March 2, 2022, 9:25am
4
When I look at the documentation for modbus integration at Modbus - Home Assistant it says the following:
unit_of_measurement
is an integer. Is it a documentation error or is this generated from the code which creates a problem in the integration?
tom_l
March 2, 2022, 9:46am
5
Itâs not auto-generated. Itâs a typo. Fixed:
home-assistant:current
â tomlut:patch-2
opened 09:45AM - 02 Mar 22 UTC
Correct unit_of_measurement type.
## Proposed change
Describe the⌠big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
## Type of change
What types of changes does your PR introduce to our documentation/website?
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR.
- [ ] Spelling, grammar or other readability improvements (`current` branch).
- [x] Adjusted missing or incorrect information in the current documentation (`current` branch).
- [ ] Added documentation for a new integration I'm adding to Home Assistant (`next` branch).
- [ ] I've opened up a PR to add logo's and icons in [Brands repository](https://github.com/home-assistant/brands).
- [ ] Added documentation for a new feature I'm adding to Home Assistant (`next` branch).
- [ ] Removed stale or deprecated documentation.
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- Link to parent pull request in the codebase:
- Link to parent pull request in the Brands repository:
- This PR fixes or closes issue: fixes #
## Checklist
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] This PR uses the correct branch, based on one of the following:
- I made a change to the existing documentation and used the `current` branch.
- I made a change that is related to an upcoming version of Home Assistant and used the `next` branch.
- [x] The documentation follows the Home Assistant documentation [standards][].
[standards]: https://developers.home-assistant.io/docs/documenting/standards
nikla
(Niklas)
March 2, 2022, 10:05am
6
That was quick!
My main problem still remains though. Why is the unit not used for the sensor frpm modbus integration?
tom_l
March 2, 2022, 10:24am
7
Assuming that you have restarted Home Assistant after making the changes to the Modbus sensor the only other thing I can think to advise you to do is to clear your browser cache.
nikla
(Niklas)
March 2, 2022, 12:42pm
8
I restarted my HA again, I cleared browser cache, I have tested on different computers and on different browsersâŚ
It still looks the same, there is no unit on the modbus integration temperature.
petro
(Petro)
March 2, 2022, 12:46pm
9
It wonât move to the other graph until the wrong unit of measurement is purged from the system. That can take up to 10 days depending on your recorder setup.
tom_l
March 2, 2022, 12:59pm
10
New measurements should show up with the new unit though.
petro
(Petro)
March 2, 2022, 1:01pm
11
Yes, the entity will have the correct unit, however itâs unclear what OP is looking at. I would wager that heâs still looking at the graphs.
nikla
(Niklas)
March 2, 2022, 7:58pm
12
I created a new modbus sensor with unit_of_measurement
and it worked directly. I assume @petro was correct above.
