I’ve been using HasOS on an old raspberry pi 2 with a GoControl CECOMINOD016164 HUSBZB-1 USB Hub for zigbee, and perhaps someday z-wave. Everything was working great for the most part, and things “just worked” with a variety of devices from aquara, eWeLink, sengled, etc.
I recently decided to transfer my install over to a pi 4, to give myself room to grow and expand. I backed up my home assistant config, flashed the pi4 USB drive to a fresh install of HasOS, and booted things up. At the initial setup screen, I uploaded the backup from my pi2, and all my configuration seems to have been imported successfully.
Ever since I transitioned though, I’m having connectivity issues with all my zigbee devices, with many seeming to be unable to connect. If I look at the entities under my ZHA integration, 11/36 entities are down, corresponding to 5/14 devices.
I then manually removed all my zigbee devices and made sure they were powered off where applicable, and went to add a brand new cheap tekber smart plug. I already had one of these in my network with the pi2, so I know it should fundamentally work. Unfortunately both the old and the new ones refuse to pair, with nothing in the “show logs” section of the zha pairing screen. I need at least one of the plugs working as a powered node in order to get reception on all my devices, but while pairing I’m more or less right beside the pi4.
I’m at a bit of a loss for where to go from here. I’m not afraid of linux or command line things in general, so if I need to get my hands dirty to troubleshoot or diagnose what’s happening I’m more than happy to. Any advise would be much appreciated.
