Hi, I tried to make an automation to dim a hue light with a fibaro dimmer which acts sollely as a remote. It should do the following:
1: long press key 1 > the hue light should brighten until release of the key.
2. the next time the key is long pressed the hue light should dim until release.
3. the next time the key is long pressed the hue light should brighten.
4. and so on…
I made an automation which should switch between 2 option based on a toggle switch which is set on or off based on the option which is executed. But somehow I can’t make it work.
alias: 'Light: Dim one light until release (Duplicate)'
description: ''
- platform: device
device_id: 80bb47cd550fa2d7f660000337fab85a
domain: zwave_js
type: event.value_notification.scene_activation
property: sceneId
property_key: null
endpoint: 0
command_class: 43
subtype: Endpoint 0
value: 12
- platform: device
domain: zwave_js
property: sceneId
property_key: null
endpoint: 0
command_class: 43
subtype: Endpoint 0
value: 13
condition: []
- choose:
- conditions:
- condition: state
entity_id: input_boolean.dimmer_keuken_state
state: 'on'
sequence:
- repeat:
while:
- condition: trigger
sequence:
- service: light.turn_on
brightness_step_pct: 5
entity_id: light.signify_netherlands_b_v_lwo001_ad7feb08_level_on_off
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 50
- conditions:
- condition: state
state: 'off'
sequence:
- repeat:
while:
sequence:
brightness_step_pct: -5
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 50
default: []
- service: input_boolean.toggle
data: {}
mode: restart
