Is there any easy, plug and play way to smartify this without soldering or modding? I like to leave the fan at the bare minimum when I sleep and raise it a bit during the day. With the dumb plug all I need to do is leave the fan to max position and adjust the dimmer plug’s little knob
Don’t do that unless you want things to catch fire. Dimmer switches are for resistive loads like (incandescent) light bulbs. They are not designed for the inductive loads like a fan motor.
yeah guys but i’m doing this since 11 years day and night 4 months per year and i’m still alive, so I assume it will not catch fire. The fan HAS 3 speed positions so I assume it is already “dimmerable”. The fan is this one:
any suggestion on how to do from HA the same thing I do manually with the knob of the dimmer plug?
I found a Moes dimmer smart plug and on the website they say it is suitable for fans, but the behavior is not so clear and the speed is never the same somehow.
Do NOT attach an induction load (eg an electric motor) to a ‘dimmer’
They are NEVER ‘dimmable’ it can cause a fire. Just because yours hasn’t yet does not mean it is safe
Dimmers modulate voltage while fan controls modulate amperage. You MUST use a fan controller. (you will not find a plug in one, not in the US at least because of code and not plugging in fans to dimmers.)
Fan == fan controller NOT dimmer works differently as to not cause a fire.
The only further “advice” I will give you regarding this subject is to ask you to pm me your address. Need to know where to send the flowers once your assumptions prove incorrect.
Point here is that while many AC motors can be controlled with phase cut dimmer (triac), you don’t know internals of your fan motor. Neither you know the onboard speed control circuit. So wiring them in series with dimmer that is not even allowed for motors is 3x no-go. Adding there the fact you are running it while you are sleeping, it becomes 4x.
Good luck.
sorry for the wrong words I used, of course my needing is for a fan controller.
By the way MOES sells a smart plug that is officially suitable for fans and I have it in my hands, cons are that is a tuya device and I find it a bit unreliable
Can I use sonoff iFan4? should it entirely replace the controller of the fan or not?
the controller is “separated” from the fan engine and probably easily removable:
I have used the Levitin on fans, low voltage garden lighting, and it is currently controlling our waterfall pump. Unfortunately, they have been discontinued and used ones are very difficult to find.I found one on ebay a couple months ago and snatched it up as a spare.
I really hate fan controllers because low and medium are never the right speed. And for some reason, manufacturers aren’t figuring out that it needs to be programmable… perhaps as part of the z wave configuration. I’d buy three of them right away.If there was such a thing.
i BELIEVE the sonoff thing auto regulates by itself every time it is turned on, because if you turn it on at minimum speed, it goes full speed for a fraction of a second and then slows down. So far it’s working fine and well (and it is an offline device, despite sonoff)
