Dimmer for Aqara buttons (1st gen)
Dim lights by long pressing a button. The entity must be ‘on’ during hold.
This is my first blueprint so I am happy for feedback. It has currently only been tested with Aqara buttons (1st gen). Please report any other switches that work.
I noticed that setting a very short transition_step_length does not work. Maybe it is my system that cannot handle it…
blueprint:
  name: Single button dim switch
  description: Switch a light on/off by pressing a button.
    Dim it up/down (depending on it's current state) by holding the same button.
  domain: automation
  input:
    button:
      description:
        Entity representing a physical push button (which restores its position
        when released).
      selector:
        entity:
          domain: binary_sensor
    light:
      selector:
        entity:
          domain: light
    brightness_threshold:
      name: Brightness threshold
      description: If the light brightness is above this value,
        the light is going to dim down when holding the button.
      default: "130"
      selector:
        number:
          min: "0"
          max: "255"
    brightness_step_pct:
      description: Percentage brightness increase/decrease in each transition step.
      default: "7"
      selector:
        number:
          min: "1"
          max: "100"
          unit_of_measurement: "%"
    transition_step_length:
      name: Transition step length
      description: Length of each transition step.
      default: "0.3"
      selector:
        number:
          min: "0"
          max: "5"
          step: "0.01"
          unit_of_measurement: s
mode: restart
  - platform: state
    entity_id: !input button
    to: "on"
  - variables:
      brightness_step_pct_positive: !input brightness_step_pct
      brightness_step_pct_negative: "{{ brightness_step_pct_positive|int * -1 }}"
      light: !input light
      max_brightness: 255
      min_mireds: "{{ state_attr(light, 'min_mireds') }}"
      max_mireds: "{{ state_attr(light, 'max_mireds') }}"
      initial_mireds: "{{ state_attr(light, 'color_temp') | float(666) }}"
      initial_brightness: "{{ state_attr(light, 'brightness') | float(0.0) }}"
  - choose:
      - conditions:
          # when brightness level is high
          - condition: numeric_state
            entity_id: !input light
            attribute: brightness
            above: !input brightness_threshold
        sequence:
          # dim down
          - repeat:
              while:
                - condition: state
                  state: "on"
              sequence:
                - service: light.turn_on
                    transition: !input transition_step_length
                    brightness_step_pct: "{{ brightness_step_pct_negative }}"
                    color_temp: "{{ max_mireds - ((max_mireds - initial_mireds) * (state_attr(light, 'brightness') / initial_brightness)) | int }}"
                - delay: !input transition_step_length
    default:
      # otherwise, dim up
      - repeat:
          while:
            - condition: state
              state: "on"
          sequence:
                brightness_step_pct: "{{ brightness_step_pct_positive }}"
                color_temp: "{{ initial_mireds - ((initial_mireds - min_mireds) * ((state_attr(light, 'brightness') | float(0.0) - initial_brightness) / (max_brightness - initial_brightness))) | int }}"
Credits: 💡 Single button on/off/dim switch
