DIMMER KNOB --> HASS --> Foscarini's MyLight (Casambi)
Hi all,
Friends of my are having a Foscarini’s MyLight and want to be able to dim the lights via a dimmer knob. Unfortunately, there are non available, due to the fact that it is only dimmable via the Casambi app.
How I see that it would be possible:
Integrate Casambi LED driver with a BT dongle to Home Assistant. Use a dimmer knob to have a physical knob in their home, that is connected via Home Assistant. Make an automation with parameters of the knob, corresponding with the dimming values of the light.
My questions:
  1. Is there a possibility to connect to this light, without the Casambi Gateway?
  2. What knob would you suggest that would fit in a 55 Gira system and what protocol would be best to use?
Big thanks in advance!
Lots of views, no reactions. Did you get this working @deanius ?
