Dimmer to wled Template
I am trying to better learn templating as autmotion and would like to accomplish the following:
  • Entity zwave dimmer switch dim_1 provides brightness level based on its state
  • Entity wled light light.wled1 is then set to the same brightness level as the dimmer (as a percent) so 100%=full brightness (255 for wled) and 50%=half brightness (127 for wled).
Thank you in advance
Few questions.
  • what have you tried?
  • how does the dimmer work? Full 0-100 slider or buttons/step_increments?
  • how are you handling on/off?
The dimmer is a paddle switch and have not programmed anything yet other than controlling on-off of wled direct from HA.
And does the paddle switch provide events or does HA report a state when it is pressed?
It shows state (brightness) as a level between 0-255.
My WLED works with 0-255 brightness values ok.
Will have to see how you’ve tried it to see where it might have gone wrong.
