Dimming an LED... a new attempt
Could someone please help me out of this mess???
output:
  - platform: esp8266_pwm
    pin: GPIO15
light:
  - platform: monochromatic
    output: output_esp8266_pwm_1
        #Rotary 1 LED1
  - platform: rotary_encoder
    name: Rotary Encoder Sensor 1
    pin_a:
      number: GPIO12
      inverted: true
      mode:
        input: true
        pullup: true
    pin_b:
      number: GPIO13
      inverted: true
      mode:
        input: true
        pullup: true
    on_clockwise:
      - then:
          - logger.log: clockwise
          - light.dim_relative:
              relative_brightness: +5%
          - globals.set:
              value: dimmer1 + 5
    on_anticlockwise:
      - then:
          - logger.log: anticklockwise
              relative_brightness: -5%
          - globals.set:
              value: dimmer1 - 5
globals:
  - id: dimmer1
    type: int
I think i ran into the woods and could’nt find out…
Turning the rotary should increase/ decrease the value of the variable and set the Light Level (LED).
First step of my first project…
The other attempts can be seen via my Profile
Thanks and have a nice sunday
So what happens (and what doesn’t)? What you get on esphome logs?
Had to kick off globals.set but then it works.
[21:27:56.975][D][main:530]: clockwise
[21:27:56.975][V][light:082]: 'Monochromatic Light' Setting:
[21:27:56.978][V][light:095]:   State: ON
[21:27:56.979][V][light:070]:   Brightness: 5%
[21:27:56.979][V][light:133]:   Transition length: 1.0s
[21:27:56.992][V][sensor:077]: 'Rotary Encoder Sensor 1': Received new state 1.000000
[21:27:56.992][V][sensor:125]: 'Rotary Encoder Sensor 1' >> 1 steps
[21:27:58.567][D][main:530]: clockwise
[21:27:58.567][V][light:082]: 'Monochromatic Light' Setting:
[21:27:58.567][V][light:070]:   Brightness: 10%
[21:27:58.588][V][light:133]:   Transition length: 1.0s
[21:27:58.589][V][sensor:077]: 'Rotary Encoder Sensor 1': Received new state 2.000000
[21:27:58.589][V][sensor:125]: 'Rotary Encoder Sensor 1' >> 2 steps
[21:28:00.044][D][main:540]: anticklockwise
[21:28:00.045][V][light:082]: 'Monochromatic Light' Setting:
[21:28:00.045][V][light:070]:   Brightness: 5%
[21:28:00.055][V][light:133]:   Transition length: 1.0s
[21:28:00.055][V][sensor:077]: 'Rotary Encoder Sensor 1': Received new state 1.000000
[21:28:00.056][V][sensor:125]: 'Rotary Encoder Sensor 1' >> 1 steps
[21:28:01.070][D][main:540]: anticklockwise
[21:28:01.070][V][light:082]: 'Monochromatic Light' Setting:
[21:28:01.070][V][light:095]:   State: OFF
[21:28:01.096][V][light:070]:   Brightness: 0%
[21:28:01.096][V][light:133]:   Transition length: 1.0s
[21:28:01.096][V][sensor:077]: 'Rotary Encoder Sensor 1': Received new state 0.000000
[21:28:01.101][V][sensor:125]: 'Rotary Encoder Sensor 1' >> 0 steps
The Brightness increases and decreases but how do i store the value because i need to switch the light on and off via the push button and restore the previous brightness.
Afaik light should retain the brightness between on and off.
Do you mean you cut power of the Esp?
