Im trying to setup an automation with these items:
Schneider Wiser Dimmer Puck Relay
Schneider Wiser Battery Switch
And it almost works, only issue is that when im dimming down, it ends up turning off the light. Instead of stopping at the minimum limit. Have tried so much now and dont know what to do.
I have made this automation/yaml:
alias: Kontrol Lys Entre Gang
description: ""
triggers:
- event_type: zha_event
event_data:
device_ieee: 4c:5b:b3:ff:fe:2b:24:fc
command: move_with_on_off
trigger: event
event_data:
command: move
trigger: event
event_data:
command: stop
trigger: event
event_data:
command: "on"
trigger: event
event_data:
command: "off"
trigger: event
conditions: []
actions:
- choose:
- conditions:
- condition: trigger
sequence:
- repeat:
sequence:
- data:
entity_id: light.spots_entre_og_gang
brightness_step_pct: 10
action: light.turn_on
- delay:
milliseconds: 500
while:
- conditions:
sequence:
- repeat:
sequence:
- data:
brightness_step_pct: -10
- delay:
milliseconds: 500
while:
- condition: numeric_state
attribute: brightness
above: 10
- data:
brightness: 25
- conditions:
sequence:
- target:
data: {}
- conditions:
sequence:
- target:
action: light.turn_off
data: {}
mode: restart
Hope anybody can help me.
Best regards,
Jonathan
