I have a number of Honeywell ZW3010 in wall dimmer switches. The issue is that I can’t get them to transition smoothly (fade up or fade down). I just migrated over from hubitat and I’m sure that functionality works with these devices. If I set the config to the device to change the dimmer duration to 2 seconds, that works just fine for exactly one cycle. Then it appears HA overwrites that 2 with a zero. If I set transition time to 2 in the light.turn_on service, it seems to have no effect. It appears the transition time isn’t mapped over correctly to the dimming duration parameter of the switch. How would I go about adjusting that mapping? I’m using zwave2mqtt by the way.
Here is a sample automation:
- alias: Test on
- platform: state
entity_id: input_boolean.test_bit
to: 'on'
- service: light.turn_on
entity_id:
- light.livingroom_dimmer
transition: 2
brightness_pct: 50
- alias: Test off
- platform: state
to: 'off'
- service: light.turn_off
entity_id:
# data:
# transition: 2
# brightness_pct: 0
I am having the same exact issue as you. I have the same exact dimmers as you, as well as some Zooz dimmers that have the “Dimming Duration” key. I am using zwave2mqtt as well. I really like this setup, but I cannot figure out how to get the “Dimming Duration” to map over to the transition property. I am using Node Red and having no luck with that either.
I have a ZEN27 Dimmer and every time I try to adjust the dimming level in HA, OpenZWave starts spamming messages about the dimming value and dimming duration several times per second. I have to restart the addon to get it to stop the endless loop. I’m running HA 0.117 on Zooz firmware 3.01.
Were you able to resolve this with the ZW3010 and zwave2mqtt? I’m having the same issue with the same dimmer. If I’m following correctly, it sounds like the solution for the Zooz dimmer was to downgrade firmware. But I can’t find anything about changing the firmware with the ZW3010 dimmer. Has anyone had any luck getting transition time to work with it?
