Direct binding and decoupled mode switches
Hey! I’m going a little bonkers trying to figure out which switches to use.
My idea is to use a 230V switch without a neutral wire, just so everything still works even if something happens to my Home Assistant setup. Then I want to set up direct binding between the switch and a smart bulb, and run the switch in decoupled mode.
What I can’t wrap my head around is whether there are any switches that actually support both of these functions — direct binding and decoupled mode.
My setup is a Sonoff Zigbee dongle, zigbee2mqtt with Home Assistant OS on a raspberry pi.
Any recommendations would be greatly appreciated!
What type of connection are we talking about? Wifi does not support direct binding - at least not universally. Some brands may have proprietary support.
Zigbee does, but in my experience it is a hit or miss because of lacking support or incompatibilities. Plus in ZHA it is a pain to set up.
Z-wave always works like a charm with direct binding and I have yet to see a device that does not support it, probably due to the chips all coming from the same source as it is licensed technology. Thet is where the high prices come from.
Dooh. I forgot to say what I run in my system. I edited that in now in my post.
I’ve come to understand thats its a little bit hit or miss with zigbee switches. Which is sad of course and maybe I just end up risking that my setup never actually gives up. Tho I would love to find a switch that works, which some seem to have found.
It is of course both the switch and the light that need to work together. At lease Z2M is a step in the right direction because I understand that makes the process of binding a lot easier than ZHA.
Of course, but its a difference between binding them through Z2M or direct binding. I want to do a direct binding switch-bulb and then run the automations etc through HA - its a case of redudancy if my HA fails, in which case I will have a very angry girlfriend.
Sounds good if its easier with Z2M.
You havn’t got any recommendations for a switch yourself?
No sorry. I gave up on binding with Zigbee because I had no places that were crucial. Most of my stuff needing it is z-wave.
You can install custom firmware on tuya switch/relay and enable those features
Here’s a list of the devices compatible
Have you used Z-wave direct association with any Z-wave smart bulb, by any chance?
Not smart bulbs personally, I only use smart dimmers and dumb bulbs. But technically that is the same. It is just that the dimmer is not in the bulb. Mostly Heat-it buttons with Fibaro smart dimmers. 13 dimmers, 7 single switches and 2 double switches. All directly linked to about 20 smart remotes. And of course the remotes have scenes too, but those run through HA. I usually use double switches. One directly bound to the light and the other for scenes. That way I can always control the lights, even if HA is down.
