Dear Communitiy!
I have bought NodOn SIN-4-RS-20 roller shutter modules due to their small form factor and their large operations temperature range. I have a use case that I have not yet managed to solve:
I do not have a 4-wire installation cable between my outdoor roller shutter motor and my indoor UP/DOWN push button (Siemens Delta 5TA2114), only 3 wires (L, N, GND). It is impossible to replace this cable. Therefore I have to place the SIN-4-RS-20 module outside, close to the motor.
In order top operate the motor, I could use any Zigbee or even WLAN based switch module and my Home Assistant gateway with Zigbee2MQTT and SONOFF Zigbee 3.0 USB Dongle Plus (TI CC2652P + CP2102N) in between. However, I want my Siemens Delta 5TA2114 push buttons to operate the motor independent of any Zigbee gateway under normal conditions. The solution I found is: direct Zigbee binding.
So, my idea is to use two Sin-4-RS-20 for each roller shutter, one indoor as simple Zigbee dual-switch behind the Siemens 5TA2114 push button (receiving manual impulses via I-up/I-down, M ports not wired) and the other one outside, directly connected to the motor via M-up/M-down (I ports not wired). Pushing Siemens button 1 should trigger port I-up on the inside NodOn, pushing button 2 should trigger port I-down. Both should trigger the respective Zigbee event, which is received by the Home Assistant gateway BUT ALSO directly by the outside NodOn module, triggering I-up (or respectively I-down) there. As a result, the outside NodOn module would open M-up (or M-down respectively) in order to operate the motor.
Basically, I want the outside module 1:1 synchronized with the inside module.
Wiring:
Siemens 5TA2114 [L] ----- Live (Hot) Wire
Siemens 5TA2114 [1] ----- NodOn-Inside [I-up]
Siemens 5TA2114 [2] ----- NodOn-Inside [I-down]
NodOn-Inside [L] ----- Live (Hot) Wire
NodOn-Inside [N] ----- Neutral Wire
NodOn-Inside [I-up] ----- Siemens 5TA2114 [1]
NodOn-Inside [I-down] ----- Siemens 5TA2114 [2]
NodOn-Inside [M-up] ----- n/a
NodOn-Inside [M-down] ----- n/a
NodOn-Outside [L] ----- Live (Hot) Wire
NodOn-Outside [N] ----- Neutral Wire
NodOn-Outside [I-up] ----- n/a
NodOn-Outside [I-down] ----- n/a
NodOn-Outside [M-up] ----- Motor [Up]
NodOn-Outside [M-down] ----- Motor [Down]
My question is: what do I need to do in order to synchronize the two NodOn modules via Zigbe2MQTT binding. I only see endpoint 1 and 242.
