Disable action toggle start home assistant (toggle switch with esp8266)
I’m trying to make a fysical switch connected to an esp8266 to switch a light.
I works, but when I restart homeassisant, it also toggles the light. Any idea how to solve it, or is there a better way to get this switch to toggle ?
- alias: "light switch 0"
   - platform: mqtt
     topic: /Buitenverlichting/swschuur/Switch
     payload: '0'
     service: switch.toggle
     entity_id: switch.schuurverlichting
- alias: "light switch 1"
   - platform: mqtt
     payload: '1'
Yes, if you omit the mqtt payload in the trigger, it triggers on every state change.
So you need just one automation.
Don’t know if this helps for the restart problem.
- alias: "light switch toggle"
   - platform: mqtt
Ok that is also working with one automation , but still when restart hass.io , the light goes on
I’m guessing that your mqtt device is publishing with the retain flag set, so when Hass starts it subscribes to the topic, gets a message delivered, and triggers the automation to toggle the light from off to on. You’ll need to change that code on the device and also use mosquitto_pub to publish a null retained payload to that topic to clear the current retained message.
That could be the problem, I set the retain in espeasy, also checked it out, but it’s also stiil than in hass.io?, I must publish null, mosquitt_pub with the -n -r options?
moquitto_pub -h 192.168.x.x -t /Buitenverlichting/swschuur/Switch -n -r -d
Correct. The -r option sets the retain flag and the -n option sets a null payload.
thnx, that solved the issue, now it works as expected
