Disable scene/aliases Sensor activated
I have some blinds that are blocking the window from opening and vice versa, couldn’t close properly, when the window is opened. So I have installed a door sensor, that greyes out the blinds in the dashboard, as the window is being open. I also would like to prevent them to be closed by Google assistant. I have a scene, where the blinds are closed and some aliases that could be said in order to do so. I’d like to disable that scene for GA when the window is opened, and enable it again so it can be called out.
You seem to have several ways of controlling these blinds. Rather than tweaking them all separately, how about a simple automation triggered by their state changing to “closing” and with an “open_cover” action if the window is open.
