Disabled fields - should have help applied
In the settings areas, for example : Settings → System - > General. For folks like myself who have had a HA instance for a while, have configured things in the configuration.yaml file. But when using the web UI it just disables the fields and says, “Editor disabled because config stored in configuration.yaml.”.
It would be nice for each field to minimally have a pop over help or something that says, this “field” is under the “HTTP” section in the configuration, and therefore is disabled here. That way we could slowly migrate away from the old configuration files, and to the UI when possible.
