Disabling automation from Frontend
I’m running Home Assistant 0.108.2.
In the Frontend /config/automation there’s the list of automations from my configuration file. Each one of them have a checkbox in front of it. I though it was to disable (deactivate) the automation… but it doesn’t seems to work.
For instance, I’ve created a simple test automation which toogle a light every minutes :
- alias: test
    platform: time_pattern
    minutes: "/1"
    - service: light.toggle
      entity_id: light.L22
This automation keeps running even if I unchecked it in the list of automations.
Maybe the checkbox isn’t about disactivating ? Or is it a bug ?
If you are referring to the slide switch in your image that is turned off, I can confirm that this works for me and stops my automations in the same version you are using. I have not tried it in a timed triggered automation.
Thank you Crhass.
I got it working. I was using 0.107.7 before, and couldn’t make it work on this. Before I opened this thread, I’ve try again on the lastest (0.108.2)… didn’t work either… but… I forgot to refresh the Frontend. I’ve notice it cause the design of the automation page changes.
And now, it works ! My light stop blinking when I turn of the automation.
Sorry for the mistake.
