Disabling offline cameras on zoneminder
I’m using zoneminder to manage my IP cameras but found that if one (or more) of them become offline zoneminder start to consume a lot of CPU. The real culprit should be the ffmpeg as it reports a unusual high fps to zoneminder… To avoid this I wrote a pair of automations to enable/disable the cameras. Maybe this could be useful for someone else, so I’m sharing it here.
binary_sensor:
  - platform: ping
    host: 192.168.x.x.
    scan_interval: 60
  - platform: ping
    host: 192.168.x.x
    scan_interval: 60
automation:
  - alias: disable offline camera
       - platform: state
         entity_id: binary_sensor.garage_camera
         to: 'off'
         for:
            minutes: 5
       - platform: state
         entity_id: binary_sensor.hall_camera
         to: 'off'
         for:
           minutes: 5
     - service: notify.<someone>
       data_template:
            message: "camera {{ trigger.entity_id }} offline"
     - service: shell_command.cam_control
       data_template:
          mon_id: >-
            {% if trigger.entity_id == 'binary_sensor.garage_camera' %}
              6
            {% elif trigger.entity_id == 'binary_sensor.hall_camera' %}
              4
            {% endif %}
          mon_function: None
- alias: enable online camera
      - platform: state
        to: 'on'
        for:
          minutes: 5
      - platform: state
        to: 'on'
        for:
          minutes: 5
       data_template:
            message: "camera {{ trigger.entity_id }} online"
       data_template:
          mon_id: >-
              6
              4
            {% endif %}
          mon_function: Monitor
shell_command:
  cam_control: >-
    curl -XPOST http://localhost/zm/api/monitors/{{ mon_id }}.json -d "Monitor[Function]={{ mon_function }}&Monitor[Enabled]=1"
You will have to find on zoneminder the ID for each of your camera.
Thanks for sharing.
not sure if you can edit your post so it shows up under “share your projects”?
changed as requested :-).
