Disaster after power outage
Hi all,
I lost power about a week ago and my entire system went haywire. I am using an RPI4 with Hass.io. My SD card was corrupted which I changed out but I can’t get all of my sensors back. Even when I try re-pairing sensors that worked for months it doesn’t work. The sensors are Samjin water sensors (smart things). I also have a smart things hub and the sensors pair to that no problem. Here is what comes up when I attempt to repair.
[0x0000:zdo] ZDO request 0x0036: [60, <Bool.false: 0>]
[0x8822:1:0x0402] ZCL deserialize: <ZCLHeader frame_control= manufacturer=None tsn=109 command_id=Command.Report_Attributes>
[0x8822:1:0x0402] ZCL request 0x000a: [[<Attribute attrid=0 value=>]]
[0x8822:1:0x0402] Attribute report received: measured_value=1776
[0xbfb4:1:0x0402] ZCL deserialize: <ZCLHeader frame_control= manufacturer=None tsn=102 command_id=Command.Report_Attributes>
[0xbfb4:1:0x0402] ZCL request 0x000a: [[<Attribute attrid=0 value=>]]
[0xbfb4:1:0x0402] Attribute report received: measured_value=1789
Please let me know if you have any suggestions.
