Discovery ignore and Logs
Hi
I’m bothered by logs filling up with Roku discovery error and plex errors so I added this in my configuration file but it looks it has no effect (HA restarted after change). Did I misunderstood use of that command ?
# Discover some devices automatically
discovery:
   ignore:
      - plex_mediaserver
      - roku
That should be correct. Do you have those platforms configured manually? Because I suspect that it’s that platforms that give errors and not the discovery component (that just setup the platforms).
Nope they are not yet configured manually but I figured out the issue (mistype in config file :wink: !
Problem solved, sorry for noise :smiley:
- isp5
- isp5_2
- isp6x
- isp6x_2
- mygg0303
- plex_mediaserver
- vr0008
using the homekit componet, I keep getting the discovery setup for these and I can’t figure out how to disable them… i don’t want to use any of the homekit devices in HA any ideas?
