My I’m running Home-assistant supervised on a RPI 5.
System info: Core version is 2025.2.5, Supervisor is 2025.2.4 The OS is 14.2
Piper whisper and speech_to_phrase are all installed, their logs say
discovery has been notified.
on reboot I got this log entry for wyoming.
Logger: homeassistant
Source: components/wyoming/config_flow.py:75
First occurred: 9:02:31 AM (1 occurrences)
Last logged: 9:02:31 AM
Error doing job: Task exception was never retrieved (None)
File "/usr/src/homeassistant/homeassistant/helpers/discovery_flow.py", line 137, in _async_start
await gather_with_limited_concurrency(FLOW_INIT_LIMIT, *init_coros)
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 114, in gather_with_limited_concurrency
return await gather(
...<2 lines>...
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 112, in sem_task
return await task
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1309, in async_init
flow, result = await self._async_init(flow_id, handler, context, data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1344, in _async_init
result = await self._async_handle_step(flow, flow.init_step, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 490, in _async_handle_step
result: _FlowResultT = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/wyoming/config_flow.py", line 75, in async_step_hassio
entry.data[CONF_HOST] == uri.hostname
KeyError: 'host'
