Disk space problem , tmp files somewhere?
hallo i have home assistant blue odroid with 128gb , i have some issues on disk space, i think it should be some undeleted temp/swap files on the 128gb memory cause i have usually only 5gb free , i should have a lot more, and when it tries to make the backup (11gb ) on the external drive it fullfill the 128gb disk until it goes to zero and then crash , then i reboot the machine and it stays are zero disk free, i deleted all the backup in the base memory , i have nothing more to delete, and i would like some help from someone that tells me where i should look for tmp files to delete …
I have very basic skills on terminal .
thanks for help
Found a solution for this problem?
