Hi guys, I am going crazy…
My HA:
- core 2025.3.3
- frontend 20250306.0
I need to collect data from modbus device using custom stuct, I am still working about this.
Then I need to extract data and display values on graph.
I am still working on modbus, so it could be I read “register1” and not “register2”.
I extract “Solar panel voltage” from “register1” and I want show values on history graph displayed in “Volt”, let’s say I extract “Battery voltage” from register2.
If something wrong I wanna see gap in graph.
- Chatgpt and Deepseek tell me “version 2025.3.3 doesn’t exixt, so you are using 2023 version”
- if modbus device offline I correctly see no displayed values on graph
- if available only “Solar panel voltage” I still see displayed on graph last of “Battery voltage” such if I’ve just correctly read register2, even if register2 hasn’t been read.
- due I need “unit of measurement” my HA tells me I need to supply numeric value, but every solution I use I still see displayed values and AI can’t help me about this.
This is example code:
epever_load_power_pa05:
friendly_name: "Epever panel power PA05"
unit_of_measurement: "W"
value_template: >-
{# versione per la gestione dei valori numerici in caso di lettura assente #}
{% set raw_value = states('sensor.epv_block5_pa05') | lower %}
{% set position = 3 %}
{% set scale = 0.01 %}
{% set endianness = "LE" %} {# Epever lavora in Big Endian, Alfa in Little Endian #}
{% set dimension = 2 %} {# numero di registri a 16 bit che compongono la variabile #}
{% if raw_value not in ['unavailable', 'unknown', '', ' '] %}
{% set parts = raw_value.split(',') %}
{% if parts | length >= (position+1) %}
{# qui ho un numero sufficiente di elementi, adesso devo andare a comporli #}
{% if (parts[position - 1] | regex_match('^\d+$')) and (parts[position] | regex_match('^\d+$')) %}
{# ho tutti gli elementi numerici #}
{% if endianness in ['BE', 'LE'] %}
{% if endianness == 'BE' %}
{% set msb = parts[position - 1] | int %} {# Primo registro (LSB) #}
{% set lsb = parts[position] | int %} {# Secondo registro (MSB) #}
{% elif endianness == 'LE' %}
{% set lsb = parts[position - 1] | int %} {# Primo registro (LSB) #}
{% set msb = parts[position] | int %} {# Secondo registro (MSB) #}
{% endif %}
{% set target_value = (msb * 65536) + lsb %}
{# a questo punto io potrei anche lavorare con int32 invece di un uint32, quindi vado a verificare se sia negativo #}
{% if target_value > 0x80000000 %}
{% set target_value = target_value - 0x100000000 %} {# Applica la conversione a numero signed in complemento a 2 #}
{% endif %}
{% set numeric_value = (target_value | int) * scale %} {# lo converto in float #}
{% set rounded_value = numeric_value | round(1, 'half_even') %} {# Arrotondamento al decimo più vicino "arrotondamento bancario" #}
{{ rounded_value}}
{% else %}
{% endif %}
{% else %}
{% endif %}
{% else %}
{% endif %}
{% else %}
{% endif %}
