Display Modbus Online/offline status on OLED display
I have setup an Esp32 with ESPhome and home assistant and it works great.
I also have a little OLED screen displaying some basic information such as IP address etc.
I am trying to configure this setup to show in the OLED screen when the modbus server is online and connected to my inverter but for the life of me I cant.
I saw there is an automation option with Modbus to trigger actions using but cant get the code to work in a way that I can use the print command to display in the OLED
Any help with some code examples would be much appreciated - not an expert by any means
Thank you
modbus_controller:
  - id: modbus_con
    on_offline:
      then:
        - logger.log: "Controller goes offline!"
You could make a template sensor to show modbus state:
binary_sensor:
Then update the state on modbus controller
on_offline:
      then:
        - binary_sensor.template.publish:
            state: OFF
on_online:
      then:
            state: ON
And print the mbstate in your display component…
Thank you Karosm
Fantastic - learned something new today - it worked perfectly
Nice!
All template sensors are handy when you don’t want to write C++ in lambdas.
