Hi everyone,
How would I go about displaying a second text_sensor homeassistant entity to display on an esp32 screen? I’ve managed to get one working!
I’m able to read in from HA with the below.
text_sensor:
- platform: homeassistant
entity_id: sensor.esp32_bluetooth_scanner
internal: true
entity_id: sensor.hotwater_mode
internal: true
and output one of these to the display with this
lambda: |-
it.printf(0, 5, id(roboto_20), id(ha_time).now().strftime("%Y-%m-%d %H:%M:%S").c_str());
std::string val = to_string(id(bluetooth).state);
it.printf(0, 20, id(roboto_20), "%s",id(bluetooth).state.c_str());
I thought this might work to display the second entity but it doesn’t compile. Where am I going wrong?
lambda: |-
std::string val = to_string(id(hot_water).state);
it.printf(0, 40, id(roboto_20), "%s",id(hot_water).state.c_str());
Any assistance greatly appreciated.
Karosm
(Karosm)
February 7, 2025, 10:23am
2
You forgot to post the second text sensor code and the error you get when compiling…
Apologies Karosm,
here’s the compile error.
Compiling .pioenvs/heltec-display/src/main.cpp.o
/config/esphome/water-display.yaml: In lambda function:
/config/esphome/water-display.yaml:71:19: error: redeclaration of 'std::__cxx11::string val'
/config/esphome/water-display.yaml:69:19: note: 'std::__cxx11::string val' previously declared here
*** [.pioenvs/heltec-display/src/main.cpp.o] Error 1
========================== [FAILED] Took 7.32 seconds ==========================
I thought I could ready two text_sensors from HA like this, do they need to be separated somehow?
text_sensor:
internal: true
internal: true
Hellis81
(Hellis81)
February 7, 2025, 10:41am
4
You are declaring the same variable twice.
I think you can do like this:
lambda: |-
or
lambda: |-
std::string val2 = to_string(id(hot_water).state);
But what is val
supposed to do? You aren’t using it in the code.
Karosm
(Karosm)
February 7, 2025, 10:49am
5
My mistake, I didn’t notice you had the second sensor already there.
Like @Hellis81 pointed, your code makes not sense.
You should print val, since you declared it for your sensor.
it.printf(0, 20, id(roboto_20), "%s", val.c_str());
and same for val2.
Thank you for your help with this. There’s a lot to learn.
