Display traccar attributes all in the same card
I added traccar integration to home assistant, but it only shows one entity.
device_tracker.aristos_vasiliou
So I can only create this card.
1
But I noticed that there’s plenty of useful information under attributes.
2
Is there a way to show these attributes in the same card?
Can I do this from lovelace without manually modifying yaml files?
If manual modification of yaml files is needed, can you point me to an example?
These are attributes of that device_tracker entity.
The Entities card supports displaying attributes:
You will have to write yaml, no UI config for most of advanced things.
type: entities
entities:
  - entity: sun.sun
    type: attribute
    attribute: elevation
I’d like to show multiple attributes on the same card. But this is not working.
Is there a way to do this?
ok, I found it. I have to repeat the entity.
type: entities
entities:
  - entity: device_tracker.aristos_vasiliou
    type: attribute
    attribute: source
    type: attribute
    attribute: battery_level
