Display weather.home info on esphome ssd1306 oled
I would like to display my weather information such as Temp, Humidity and wind velocity on the display of my TTGO T-Camera ESP32 WROVER.
Basically take the info from weather.home and have it displayed on the OLED.
weather-OLED
This is my current config for the TTGO T-Camera
Any suggestions are much appreciated.
substitutions:
  devicename: ttgocam1
  friendly_name: Steve-Cam
  ip_address: 192.168.1.100
esphome:
  platform: ESP32
  board: esp-wrover-kit
wifi:
  ssid: MyLinkSys
  password: "1234567890"
  manual_ip:
    static_ip: 192.168.1.101
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  fast_connect: on
#  ap:
#    ssid: "Ttgocam1 Fallback Hotspot"
#    password: "1234123412"
#    ap_timeout:
#      seconds: 30
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
binary_sensor:
  - platform: gpio
    pin: GPIO33
    device_class: motion
  - platform: gpio
    pin:
      number: GPIO34
      mode: INPUT_PULLUP
      inverted: True
  - platform: status
  - platform: wifi_signal
    name: $friendly_name WiFi Signal
    update_interval: 10s
  - platform: uptime
esp32_camera:
  external_clock:
    pin: GPIO32
    frequency: 20MHz
  i2c_pins:
    sda: GPIO13
    scl: GPIO12
  data_pins: [GPIO5, GPIO14, GPIO4, GPIO15, GPIO18, GPIO23, GPIO36, GPIO39]
  vsync_pin: GPIO27
  href_pin: GPIO25
  pixel_clock_pin: GPIO19
  power_down_pin: GPIO26
  resolution: 640x480
  jpeg_quality: 10
  vertical_flip: true
  horizontal_mirror: true
i2c:
  sda: GPIO21
  scl: GPIO22
font:
  - file: "fonts/times-new-roman.ttf"
time:
  - platform: homeassistant
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.strftime(64, 0, id(tnr1), TextAlign::TOP_CENTER,"%d-%m-%Y", id(homeassistant_time).now());
      it.strftime(64, 64, id(tnr1), TextAlign::BASELINE_CENTER, "%d-%m-%Y", id(homeassistant_time).now());
      it.strftime(64, 128, id(tnr1), TextAlign::BASELINE_CENTER, "%A", id(homeassistant_time).now());
See the example here:
for displaying external sensors.
OK, this is what I got. What do you think? I really don’t understand how to use lamda’s such as the %s, I don’t understand what varible the “s” represents. Just so you know, I am by no means a programmers but try to get by.
substitutions:
esphome:
  platform: ESP32
wifi:
  ssid: linksys
  password: "password"
  manual_ip:
  fast_connect: on
#  ap:
#    password: "password"
#    ap_timeout:
#      seconds: 30
# Enable logging
logger:
api:
ota:
binary_sensor:
  - platform: gpio
    pin: GPIO33
  - platform: gpio
    pin:
      number: GPIO34
      mode: INPUT_PULLUP
      inverted: True
  - platform: status
  - platform: uptime
#  - platform: homeassistant
#    entity_id: sensor.weathermet_temperature
#    id: out_temp
mqtt:
  broker: 192.168.1.207
  username: MQTT
  password: password
text_sensor:
  - platform: mqtt_subscribe
    topic: weather/temp
#display:
#  - platform: ...
#    lambda: |-
#      it.printf(0, 0, id(font), "The Temp is: %s", weather.home.state.c_str());
esp32_camera:
  external_clock:
    pin: GPIO32
    frequency: 20MHz
  i2c_pins:
    sda: GPIO13
    scl: GPIO12
  vsync_pin: GPIO27
  href_pin: GPIO25
  resolution: 640x480
  jpeg_quality: 10
  vertical_flip: true
i2c:
  sda: GPIO21
  scl: GPIO22
font:
time:
display:
    address: 0x3C
    lambda: |-
      it.strftime(64, 0, id(tnr1), TextAlign::TOP_CENTER,"%s",  id(weather.home.now());
#      it.strftime(64, 0, id(tnr1), TextAlign::TOP_CENTER,"%d-%m-%Y", id(homeassistant_time).now());
#      it.strftime(64, 64, id(tnr1), TextAlign::BASELINE_CENTER, "%d-%m-%Y", id(homeassistant_time).now());
#      it.strftime(64, 128, id(tnr1), TextAlign::BASELINE_CENTER, "%A", id(homeassistant_time).now());
Did you get this working?
I did not, got the date to display but not the current weather
Check this example.
The section with sensors is what you need to change with the correct entity ids.
