Display website on internal network through duckdns routed hassos
I am not sure if this is the right category to post this in but here it goes. I have some internally hosted websites on a separate raspberry pi that I would like to integrate into my home assistant dashboard via an Iframe_panel, however due to the fact that I am using duckdns I can not access internal network IP addresses. I have tried setting up zerotierone and wireguard in an attempt to VPN to these sites but I cannot seem to get the configuration right does anyone have any idea how to do this? If possible I would like to avoid punching anymore holes in my gateway.
Thanks!
Do you need to access these sites remotely or only locally?
If it is only locally, you can setup a reverse proxy. If you want to access them also remotely, you’d need to secure them with SSL.
