Displaying a defined variable on Lovelace
Hi folks
I have an automation which defines several variables every hour, pulling data from Google Sheets. I’d like to display that text on Lovelace somehow. What would you do?
Thanks in advance
Roger
Options:
  1. Stuff the value in the appropriate typed input_* helper for your data then display that.
  2. If it’s text over 255 char. Then create a trigger text template sensor and store it there
I think trigger based template sensors are listed under template in the cookbook The Home Assistant Cookbook - Index
Either way then youll either use the appropriate card for the helper entity you create or something like the markdown card if you use a trigger based sensor
Thanks! Option 1 for me.
This isn’t doing anything, not sure why. The helper id is correct…
action: text.set_value
metadata: {}
  value: hellooooo
  entity_id: input_text.woodmans_hut_today
Inout_text. Set value… two different calls. (yes stupid I know) :sunglasses:
