Hi everyone,
I’m trying to create a template in Home Assistant that reads a numeric sensor (‘sensor.defro_bledy’), converts its value to binary, calculates which bits are set to ‘1’ (counting from the right), and then displays corresponding error messages from a dictionary.
For example, if the sensor value is ‘34’, the binary representation is ‘100010’. I expect the active bit positions to be ‘[2, 6]’, which should then map to the following errors:
- Bit 2 → “Błąd wentylatora nawiewu”
- Bit 6 → “Błąd czujnika temperatury wyrzut”
Here is what I have so far, this part correctly calculates the bit positions:
{% set val = states('sensor.defro_bledy') | int(0) %}
{% set binary = '{0:b}'.format(val) %}
{% set data = namespace(positions=[]) %}
{% for i in range(binary | length) %}
{% if binary[-1 - i] == '1' %}
{% set data.positions = data.positions + [i + 1] %}
{% endif %}
{% endfor %}
Value: {{ val }}
Binary: {{ binary }}
Bit positions: {{ data.positions }}
I also have a dictionary of errors:
{% set errors = {
1: "Błąd wentylatora wywiewu",
2: "Błąd wentylatora nawiewu",
3: "Błąd czujnika temperatury zewnętrznej",
4: "Błąd czujnika temperatury wywiewu",
5: "Błąd czujnika temperatury nawiewu",
6: "Błąd czujnika temperatury wyrzut",
7: "Błąd czujnika temperatury nawilżacza",
10: "Błąd czujnika przepływu wywiewu",
11: "Błąd czujnika przepływu nawiewu",
12: "Błąd czujnika nawilżacza",
13: "Błąd czujnika nagrzewnicy GWC",
14: "Błąd czujnika temperatury nagrzewnicy nawilżacza",
15: "Błąd wentylatora wywiewu przepływ",
16: "Błąd wentylatora nawiewu przepływ"
I’ve tried combining these to show the active errors like this:
{% set active_errors = [] %}
{% for pos in data.positions %}
{% set pos_str = pos | string %}
{% if errors[pos_str] is defined %}
{% set active_errors = active_errors + [errors[pos_str]] %}
{% endif %}
{% endfor %}
Active errors: {{ active_errors }}
But I keep getting an empty list, even though I know some bits are set. I’ve tried using integer and string keys in the dictionary, ‘append()’ vs list concatenation, and different looping techniques, yet nothing seems to work.
My questions:
- What is the correct way to map bit positions to a dictionary of errors in Home Assistant templates?
- Is there a better approach to calculate and display active errors from a numeric sensor that represents flags?
Any guidance or working examples would be greatly appreciated.
Best regards,
Piotr
