Displaying .PNG image with transparency
I am working on making a smart touchscreen thermostat using an ILI9341 display and ESP32. I would like to use .PNG images for the up and down arrows. The issue I am having is that they only display with black in any area that is supposed to be transparent. I tried to using the Image file type set to TRANSPARENT_BINARY which actually showed the transparent parts as transparent but whited out the rest.
Is there any way to achieve what I want or should I just find a workaround? Any help would be appreciated.
What do your pics look like?
Thanks for responding.
I started with this downloaded image as a test:
Then I cropped it to this:
Here is the relevant code:
image:
  - file: "splash.png"
    resize: 400x 300
    type: rgb24
  - file: "up.png"
    resize: 175 x 75
    type: rgb24
  lambda: |-
      //background image
      it.image(0, 0, id(my_image));
      //raise temp image
      it.image(215, 5, id(my_image1));
It shows up this:
I don’t know;)
You could always use mdi icons if you get stuck with images.
I can figure out a workaround for sure, I was just looking for a relatively easy way to end up with a really polished look for my thermostat.
Thank You
Yeah I know the feeling when you “want it to look slick”… Good luck hope you get more bites…
@cmj118 any luck with this? I have a similar issue and looking for a solution :slight_smile:
No sorry, I had go another route.
use RGBA
  • RGB24: Full RGB color stored. Uses 3 bytes per pixel.
  • RGBA: Full RGB color stored. Uses 4 bytes per pixel. Any pixel with an alpha value < 127 will not be drawn.
