mamvcivm
(Andrew)
December 5, 2025, 10:29pm
1
I have a Shelly EM integrated with HA using the official Shelly integration. I can display the current power consumption in a dashboard using the entity id: 120a_power , however, I’d now like to display this value on a standalone lcd display…
Perhaps a picture might help:-
As you can see, I currently have the TTGO device displaying the output of the BME/BMP280, I’d like to modify the code so that the TTGO displays the Shelly Power and possibly the corresponding cost…
I just can’t get my head round the coding syntax…
Karosm
(Karosm)
December 6, 2025, 7:47pm
2
You forgot to post the code you’d like to modify.
mamvcivm
(Andrew)
December 6, 2025, 8:00pm
3
Ah, sorry, I don’t have any working code for showing the Shelly EM - I don’t know where to start with it. Having said that, I did try and work it out; I’m assuming I need a sensor , with platform : Shelly EM (?), I assume I need to name it and give it an id … I tried adding the following to the current yaml, but had to # it out in order to allow the TTGO to continue to work…
# - platform: Shelly_em
# power:
# name: "Power"
# id: 120a_power
- platform: bme280_i2c
temperature:
name: "BME280 Temperature"
filters:
- offset: 0.25 # reduce temp by 2 deg C
oversampling: 16x
Karosm
(Karosm)
December 6, 2025, 9:19pm
4
Is your display running esphome? If so, you might want to update the category of this topic.
mamvcivm
(Andrew)
December 6, 2025, 10:17pm
5
It is, I’ve redefined it as the ESPHome category.
mamvcivm
(Andrew)
December 12, 2025, 9:09pm
6
Had some help on the ESPHome Facebook page - they pointed me to:
So, my code is:
number:
- platform: homeassistant
entity_id: sensor.120a_power
Karosm
(Karosm)
December 12, 2025, 10:34pm
7
Nice that you resolved it! Next time don’t be shy with your yaml, just post it all.
mamvcivm
(Andrew)
December 13, 2025, 10:18pm
8
No problem:
captive_portal:
number:
i2c:
sda: 21
scl: 22
scan: True
# handle the two built-in push buttons:
binary_sensor:
- platform: gpio
pin:
number: GPIO0
inverted: True
mode:
input: True
pullup: True
filters:
- delayed_on: 10ms
- delayed_off: 10ms
# optional: this dims the display backlight:
on_press:
- light.dim_relative:
relative_brightness: 5%
transition_length: 0.1s
brightness_limits:
min_brightness: 20%
- delay: 0.1s
- platform: gpio
pin:
number: GPIO35
inverted: True
mode:
input: True
filters:
- delayed_on: 10ms
- delayed_off: 10ms
# optional: this increases brightness of display backlight:
on_press:
relative_brightness: -5%
brightness_limits:
min_brightness: 20%
- delay: 0.1s
# handle built-in display backlight:
# use a separate "light" component to enable dimming rather than
# using the "display" property for backlight gpio
output:
- platform: ledc
pin: 4
light:
- platform: monochromatic
output: display_backlight_pwm
name: "Display Backlight"
restore_mode: RESTORE_AND_ON
effects:
- pulse:
min_brightness: 60%
max_brightness: 80%
temperature:
filters:
oversampling: 16x
pressure:
name: "BME280 Pressure"
filters:
- offset: 8.5 # increase pressure by 10 hPa
humidity:
name: "BME280 Humidity"
filters:
- offset: -10.4
address: 0x76
update_interval: 60s
font:
- file: "fonts/Roboto-Medium.ttf"
glyphs: '!"%()+,-_.:°0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz/³µ'
color:
- id: color_blue
red: 0%
green: 0%
blue: 50%
- id: color_red
red: 50%
green: 0%
blue: 0%
- id: color_green
red: 0%
green: 50%
blue: 0%
- id: color_white
red: 50%
green: 50%
blue: 50%
time:
spi:
clk_pin: GPIO18
mosi_pin: GPIO19
display:
- platform: st7789v
model: TTGO TDisplay 135X240
backlight_pin: no
cs_pin: GPIO5
dc_pin: GPIO16
reset_pin: GPIO23
rotation: 270
lambda: |-
it.printf((240 / 2), 20, id(font_roboto), id(color_red), TextAlign::CENTER, "Power: %.0f W", id(currentpower).state);
it.printf((240 / 2), 65, id(font_roboto), id(color_green), TextAlign::CENTER, "Humidity: %.0f %%RH", id(humidity).state);
it.printf((240 / 2), 110, id(font_roboto), id(color_blue), TextAlign::CENTER, "Pressure: %.0f hPa", id(pressure).state);
// Header
it.rectangle(0, 0, it.get_width(), it.get_height(), id(color_blue));
it.rectangle(0, 45, it.get_width(), it.get_height(), id(color_blue));
it.rectangle(0, 90, it.get_width(), it.get_height(), id(color_blue));
# °C
web_server:
port: 80
The code originally displayed the output of the BMP280 on the display. There’s also coding that uses the built in buttons to increase or decrease the backlight brightness.
The modified code replaces the temperature readout with the current power value from the Shelly EM.
