I have created a simple DIY Matter switch using an ESP32-C3 and Zero Code that works fine. It can be commissioned in Amazon Alexa but cannot be commissioned in Home Assistant. Are there any restrictions in Home Assistant (for example, an invalid DAC)? Why I am no able to add this device in HA?
Here is the event log:
home assistance cant comision a matter device, this is the log: 025-07-01 22:48:06.657 (Dummy-2) INFO [chip.ChipDeviceCtrl] Established secure session with Device
2025-07-01 22:48:09.031 (Dummy-2) CHIP_ERROR [chip.native.CTL] Error on commissioning step ‘AttestationVerification’: ‘src/controller/CHIPDeviceController.cpp:1283: CHIP Error 0x000000AC: Internal error’
2025-07-01 22:48:09.032 (Dummy-2) CHIP_ERROR [chip.native.CTL] Failed verifying attestation information. Now checking DAC chain revoked status.
2025-07-01 22:48:09.032 (Dummy-2) CHIP_ERROR [chip.native.CTL] Failed in verifying ‘Attestation Information’ command received from the device: err 101. Look at AttestationVerificationResult enum to understand the errors
2025-07-01 22:48:09.033 (Dummy-2) CHIP_ERROR [chip.native.CTL] Error on commissioning step ‘AttestationRevocationCheck’: ‘src/controller/CHIPDeviceController.cpp:1332: CHIP Error 0x000000AC: Internal error’
2025-07-01 22:48:09.047 (Dummy-2) CHIP_ERROR [chip.native.EM] Failed to send Solitary ack for MessageCounter:247653748 on exchange 25327i with Node: <0000000000000000, 0>:src/messaging/ExchangeContext.cpp:99: CHIP Error 0x00000002: Connection aborted
2025-07-01 22:48:09.048 (Dummy-2) WARNING [chip.ChipDeviceCtrl] Failed to commission: src/controller/CHIPDeviceController.cpp:1332: CHIP Error 0x000000AC: Internal error
2025-07-01 22:48:09.049 (MainThread) ERROR [matter_server.server.client_handler] [140090698718224] Error while handling: commission_with_code: Commission with code failed for node 4.
