This line in the daily rain sensor will probably solve these issues
availability: "{{ (states('sensor.rainsensor_flips') not in ('unknown', 'unavailable')) }}"
Personally I’ve never had the issue
Yes that will do the trick i’m sure, and it will save me from creating a separate inverted sensor.
That availability line doesn’t work anymore in new HA btw, it’s availability_template: now. I noticed some other stuff in the code as well that doesn’t work anymore (like state vs value_template).
Also, i noticed your hourly sensor that you put in binary_sensors.yaml, i’m using the utility platform for that. Doesn’t that work the same way?
It’s actually the new way of defining template sensors. I read somewhere that the other way will be deprecated in 2022.9.
Rain intensity aka mm/h will calculate the time between two tips and calculate how many mm will fall if it would keep raining that fast.
The utility you are talking about is only counting how many rain fell in the current hour. This is what the mm/h sensor looks like in a graph. It peaked 128mm/h, I think it was the most rain I had since I installed the sensor (1,5 years).
30mm of rain in 45 minutes
Ok i must have done something wrong then, i need to read that page fully. I do see both availability and av availability_template, but seemingly applying to different sections.
Ah ok, so rain intensity is like a forecast/trend, and the utility is just the total amount of rain that fell in the hour.
Stupid question, where do you add the following code?
binary_sensor:
- platform: trend
sensors:
rainfall_trend:
entity_id: sensor.rainfall_today
max_samples: 2
template:
- sensor:
- name: "Rain intensity"
unit_of_measurement: 'mm/h'
state_class: measurement
unique_id: rainfall_per_hour
state: >-
{% set rain_hour = ((state_attr('binary_sensor.rainfall_trend', 'gradient') | float(0)) * 3600) | round(1, 'floor') %}
{% if rain_hour >= 0 %}
{{ rain_hour }}
{% else %}
{{ 0 }}
{% endif %}
I have a separate binary_sensor.yaml file, the first part can go in there of course. What about the part after that? Can i put that in there as well? I tried doing that but it didn’t like it
What does your configuration.yaml looks like? You can probably put it in there, or create a file named template.yaml and include it like it’s done with binary_sensor.yaml. Then put it in there.
ok. Received my last item yesterday and started the project this morning. Done by noon. Waiting for rain now.
I would like to be notify the first sign of rain. Anyone knows how to approach this?
Use this as trigger with the current state in there
platform: state
entity_id:
- sensor.rainfall_today
I added it like this to my binary_sensors.yaml:
# Rainfall trend forecast amount of mm/h
- platform: trend
sensors:
garden_rain_sensor_1_rainfall_trend:
entity_id: sensor.garden_rain_sensor_1_rainfall_today
max_samples: 2
# Rainfall intensity
- sensor:
- name: "Garden Rain Sensor 1 Rain intensity"
unique_id: garden_rain_sensor_1_rainfall_per_hour
state: >-
{% set rain_hour = ((state_attr('binary_sensor.garden_rain_sensor_1_rainfall_trend', 'gradient') | float(0)) * 3600) | round(1, 'floor') %}
{{ rain_hour }}
{% else %}
{{ 0 }}
{% endif %}
But i get:
Configuration invalid!
Invalid config for [binary_sensor]: required key not provided @ data['platform']. Got None. (See /config/configuration.yaml, line 55).
When i check my configuration.
What is on line 55? The error is about a binary_sensor
but you haven’t shown code for one.
The rain intensity sensor does not belong in the binary_sensor.yaml.
Read the link I sent you above about splitting the configuration
I put it in template.yaml and include it as template: !include template.yaml
from the configuration.yaml, that seems to pass a configuration check.
I guess i just don’t understand the difference between your yaml code
template:
- sensor:
state: >-
{{ rain_hour }}
{% else %}
{{ 0 }}
{% endif %}
And for example, this (which is in binary_sensors.yaml ):
# Washing machine, dryer and dishwasher states
sensors:
utility_room_washing_machine_1_current:
friendly_name: "Utility Room Washing Machine Status"
delay_on: "00:05:00"
value_template: "{{ states('sensor.utility_room_washing_machine_1_current')|float(0) > 6 }}"
device_class: running
I guess i’m confused between a real template that goes in a template.yaml file and something that uses the platform template (which also uses sensors rather then sensor in it’s yaml code).
The difference is that the way the rainfall intensity is written, is the new way to define a template sensor. You could rewrite your old template sensor into the following:
template:
- sensor:
- name: "Garden Rain Sensor 1 Rain intensity" #this is a template sensor
state: >-
{{ rain_hour }}
{% else %}
{{ 0 }}
{% endif %}
- binary_sensor:
- name: "Utility Room Washing Machine Status" # This is a template binary_sensor
unique_id: utility_room_washing_machine_1_current
state: "{{ states('sensor.utility_room_washing_machine_1_current')|float(0) > 6 }}"
Ah ok, i think i get it. So in your code both sensor and binary_sensor fall under template:
I can either put this code into configuration.yaml or include it in a template: !include template.yaml
and then leave out the template:
part.
Can i mix and match? If i did want to include the new rain intensity template sensor style within say, binary_sensors.yaml (not saying i’m going to, just for my understanding), would that work and if it did, i probably would have to preface it with template:
I think i will probably put everything in a template.yaml anyway.
Thanks for your help.
Im confused. In original post, the mm/pulse is .30303
But if it tipped 6 times when you put 10mL worth of water into it then 6 tips x .30303 would be 1.8 mL
Shouldent it equal 10mL?
I know I am wrong, I just need someone to explain it to me.
Additionally, what am I doing wrong in my sensor.yaml? It wont let me restart my HA with the added stuff. Im a node red guy, so this yaml stuff is really my Achilles heel.
sensors:
washer_door_lock:
friendly_name: "Washer Door Lock"
value_template: "{{ state_attr('sensor.washer','door_lock') }}"
washer_time_display:
friendly_name: "Washer Time Display"
value_template: >
{% if is_state('sensor.washer_run_state', '-') %}
{% elif is_state('sensor.washer_run_state', 'Standby') %}
{% else %}
{{ state_attr('sensor.washer', 'remain_time') }}
{% endif %}
dryer_time_display:
friendly_name: "Dryer Time Display"
value_template: >
{% if is_state('sensor.dryer_run_state', '-') %}
{% elif is_state('sensor.dryer_run_state', 'Standby') %}
{% else %}
{{ state_attr('sensor.dryer', 'remain_time') }}
{% endif %}
- platform: time_date
display_options:
- 'date_time'
- 'date'
#CANT RESTART WITH STUFF BELOW HERE ADDED
- platform: history_stats
entity_id: binary_sensor.rain_sensor_tips
state: 'off'
type: count
start: '{{ now().replace(hour=0, minute=0, second=0) }}'
end: '{{ now() }}'
- sensor:
- name: Rainfall today
unit_of_measurement: mm
state_class: total_increasing
unique_id: rainfall_today
state: >-
{% set count = states('sensor.rainsensor_flips') | int(0) %}
{% set mm = count * 0.30303 %}
{% if count >= 0 %}
{{ mm|round(1, 'floor') }}
{% endif %}
# If you have issues with the history sensor doubling after restarting HA, add the line below (@BigG)
Simply said, the catch area is taken into account.
The sensor is written in the new template format, see the discussion above
Is there a description in this thread how to properly attach and configure the gauge woth an D1 mini and ESPhome?
If not, can somebody who did it give me a hint?
Esp8266 setup
