Diyless + esphome + viessmann vitodens 100-W not working as expected
I have the diyless shield + wemos d1 mini to control a viessman vitodens 100-W.
It seems the boiler is not turning off if target temperature is lower than the current temperature. It does it at some point but not quick enough.
Also viceverse. If the boiler is off and I increase the target temperature is not starting it but only after a while.
Starting up. Almost two hours until firing up.
Thanks a lot!
# DIYLESS Thermostat
# https://diyless.com/product/opentherm-thermostat
esphome:
  friendly_name: DIYLESS Thermostat
esp8266:
  board: d1_mini
# Enable logging
logger:
  level: INFO
# Enable Home Assistant API
api:
  encryption:
     key: !secret api_key
# Enable Over-The-Air (OTA) platform to remotely install modified/updated firmware
ota:
 - platform: esphome
   password: ""
wifi:
  ssid: !secret wifi_iot_ssid
  password: !secret wifi_iot_password
  domain: ".home.local"
  ap:
    ssid: "DIYLESS Thermostat"
    password: ""
# Enable captive portal as fallback mechanism for when connecting to the configured WiFi fails.
captive_portal:
# Enable simple web server to remotelly control the device using web interface
web_server:
# mqtt:
#   topic_prefix: opentherm-esphome
#   broker: !secret mqtt_ip
#   username: !secret mqtt_user
#   password: !secret mqtt_password
# Enable OpenTherm communication
# https://esphome.io/components/opentherm.html
opentherm:
  in_pin: 4 # WeMos D1 Mini ESP32 input pin for stacking with Master OpenTherm Shield
  out_pin: 5 # WeMos D1 Mini ESP32 output pin for stacking with Master OpenTherm Shield
# Use switches to enable/disable central heating and hot water from HA interface
# https://esphome.io/components/opentherm.html#switch
switch:
  - platform: opentherm
    ch_enable:
      restore_mode: RESTORE_DEFAULT_OFF
      internal: false
    dhw_enable:
# Use outputs to control numerical values like Central Heating setpoint using some automatic algorithms
output:
    t_set:
      min_value: 30
      max_value: 55
      zero_means_zero: true
# Use numbers to control numerical values like CH/DHW setpoint from HA interface
# https://esphome.io/components/opentherm.html#numerical-values
number:
  # - platform: opentherm
  #   t_set:
  #     id: ch_setpoint
  #     name: "Heating Setpoint"
  #     step: 1
  #     min_value: 30
  #     max_value: 80
  #     restore_value: true
  #     initial_value: 60
    t_dhw_set:
      name: "How Water Setpoint"
      step: 1
      min_value: 30
      max_value: 50
      restore_value: true
      initial_value: 60
# Use binary sensors (on/off) to monitor the states and conditions of different boiler entities.
# https://esphome.io/components/opentherm.html#binary-sensor
binary_sensor:
    ch_active:
    dhw_active:
      name: "Hot Water Active"
    flame_on:
    fault_indication:
      entity_category: diagnostic
    diagnostic_indication:
      name: "Boiler Diagnostic"
    service_request:
    lockout_reset:
    low_water_pressure:
      name: Low Water Pressure Fault
    flame_fault:
    air_pressure_fault:
      name: Air Pressure Fault
    water_over_temp:
      name: Water Overtemperature
# Enable 1-Wire bus for DS18B20 temperature sensor
one_wire:
  - platform: gpio
    pin: 14 # WeMos D1 Mini ESP32 1-wire pin for stacking with Master OpenTherm Shield
# Wired DALLAS DS18B20 sensor
- platform: dallas_temp
  name: "Wired Sensor Temperature"
  update_interval: 30s
  accuracy_decimals: 2
  filters:
    - sliding_window_moving_average:
        window_size: 5
        send_every: 2
    - heartbeat: 1s
- platform: homeassistant
  entity_id: sensor.tuya_zigbee_temperature_temperature
# OpenTherm sensors
# https://esphome.io/components/opentherm.html#sensor
  t_boiler:
    name: "Heating Temperature"
  t_dhw:
    name: "Hot Water Temperature"
  t_dhw2:
    name: "Hot Water Temperature 2"
  rel_mod_level:
    name: "Boiler Relative Modulation Level"
  t_outside:
    name: Outside Temperature
  t_ret:
    name: Return Water Temperature
  max_t_set:
    name: Max CH Setpoint
  max_t_set_ub:
    name: Upper Bound of CH Setpoint
  max_t_set_lb:
    name: Lower Bound CH Setpoint
  t_exhaust:
    name: Boiler Exhaust Temperature
  ch_pressure:
  oem_fault_code:
    name: OEM Fault Code
  oem_diagnostic_code:
    name: OEM Diagnostic Code
# Use PID Climate component for automatic boiler setpoint calculation
# https://esphome.io/components/climate/pid
climate:
  - platform: pid
    heat_output: ch_setpoint
    default_target_temperature: 22
    sensor: current_temperature
    visual:
      min_temperature: 15
      max_temperature: 30
      temperature_step:
        target_temperature: 0.5
        current_temperature: 0.1
    control_parameters:
      kp: 0.77
      ki: 0.0005
      kd: 0
      output_averaging_samples: 10
    deadband_parameters:
      threshold_high: 0.5
      threshold_low: -0.5
      kp_multiplier: 0
      ki_multiplier: 0.15
      kd_multiplier: 0.0
      deadband_output_averaging_samples: 15
    on_state:
      - if:
          condition:
          - lambda: 'return id(ch_climate).mode == CLIMATE_MODE_OFF;'
          then:
            - switch.turn_off: ch_enable
          else:
            - switch.turn_on: ch_enable
      - logger.log:
          format: "climate mode=%s, t=%.1f"
          args: ['std::string(LOG_STR_ARG(climate_mode_to_string(x.mode))).c_str()', 'x.target_temperature' ]
          level: INFO
9:04:08	[W]	[opentherm:382]
Timeout while waiting for response from device
09:04:10	[W]	[opentherm:382]
09:04:20	[W]	[opentherm:382]
09:04:31	[W]	[opentherm:375]
Protocol error occured while receiving response: NO_TRANSITION
09:04:32	[W]	[opentherm:375]
09:04:40	[W]	[opentherm:382]
09:04:40	[W]	[opentherm:375]
09:04:41	[W]	[opentherm:375]
09:04:49	[W]	[opentherm:382]
09:05:28	[W]	[opentherm:375]
09:06:15	[W]	[opentherm:375]
09:06:42	[W]	[opentherm:382]
09:06:51	[W]	[opentherm:382]
09:07:09	[W]	[opentherm:375]
09:08:17	[W]	[opentherm:382]
09:09:10	[W]	[opentherm:382]
09:09:39	[W]	[opentherm:375]
Protocol error occured while receiving response: NO_CHANGE_TOO_LONG
09:10:09	[W]	[opentherm:375]
09:10:41	[W]	[opentherm:382]
09:10:43	[W]	[opentherm:382]
09:11:01	[W]	[opentherm:382]
09:11:30	[W]	[opentherm:382]
09:11:39	[W]	[opentherm:382]
Noticed a lot of entries like this in the log.
Hey, did you manage to get this sorted? I am having the same kind of issues:
20:49:54 [W] [opentherm:374]
20:49:56 [W] [opentherm:374]
20:49:58 [W] [opentherm:381]
Which is weird since when using the MQTT code all works fine but when using ESPHome solution, I get this.
Nope. Never did.
Hi
that is controlled by PID, so tuning its coefficients will make it react for the changes faster, however it also means that boiler will ramp up faster.
You can try heating curve heating, when the boiler temp is controleld by the weather, and if room reaches setpoint - boiler shuts down completely. In that way room temperature will be held a bit less precise but the boiler will be in off state resulting in consumption economy.
Having this too, with a default config.
I don’t reallly understand where this msg is coming from. But will it help if I use the autotuner for the PID controller?
Now, I am just using the default values for the diyless thermostat…
To answer my own question…no, will not fix this by tuning the pid- controller parameters.
The error means that the boiler is not responding soon enough or with the expected value. So chances are that the boiler is not following the OpenTherm spec.
As I have a Atag E-series boiler (from about 2014), this could be possible. Google learned me that Atag implemented their own variant of opentherm. However, I haven’t been able to find out what they exactly changed.
I currently have Tado, which I want to ditch, with a OpenTherm gateway. I will try to find out how Tado is dealing with the boiler… wouldn’t be surprised is it’s just on/off…
Any help and thoughts are appreciated. Can’t believe I am the only one using an esphome thermostat
