Dlib, why dont you recognize me?
What am I missing?
The only thing I get is this dlib value.
device_class: face
faces: [object Object]
friendly_name: Dlib Face myface
total_faces: 1
Yea, it somewhat works… It detects faces, but it doesnt recognize them.
image_processing:
 - platform: dlib_face_identify
   source:
    - entity_id: camera.myface
   faces:
     me: /home/homeassistant/.homeassistant/www/faces/me.jpg
Alright, I figured out the problem. It was between the chair and the keyboard. That means, me.
The value
when i used the template editor using this template:
{{states.image_processing.dlib_face_myface.attributes}}
it came up with this:
{‘device_class’: ‘face’, ‘faces’: [{‘name’: ‘me’, ‘entity_id’: ‘image_processing.dlib_face_myface’}], ‘friendly_name’: ‘Dlib Face myface’, ‘total_faces’: 1}
And when i used this template:
{{states.image_processing.dlib_face_myface.attributes.faces}}
Now, I want to filter the name and I cant find the way!
How can I use a template to only show the name?
I don’t understand how the component can identify my face ?
I have to put a picture of my face in the path me: /home/homeassistant/.homeassistant/www/faces/me.jpg ?
That is correct.
Check the component documentation for more info:
It can identify a person by learning from just a single photo?
Yes. The only thing I did was to put one image of mine and one of my wife’s and it could recognize us both succesfuly. I have removed the component a long time ago but if I remember correctly, it could recognize us even when we had our heads slightly sideways. It gave me the feeling it only needed half the face to do the recognition.
I’m using Facebox for face recognition at the moment. I’m just curious which one gives the best results. Will try this out soon to compare. Thanks.
Hi, do you able to find the way to get the identification on automation. Suppose you get detected and an automated trigger happen. It will help a lot if the identification is accurate.Thanks.
dlib needs some updating. I would propose adding the image_processing.face_recognised event similar to that implemented by facebox. @masterkenobi how are you using face recognition for auth?
