I am having some zwave device issues after the 2026 update.
I want to make sure my zwave is the latest?
Diagnostics
Driver version: 15.17.1
Server version: 3.4.0
Home ID: 4125492050
Home ID: 4125492050
No, that’s not the latest, but that is the wrong question. It depends on how you’ve installed Z-Wave JS, because unless you are building your own you don’t control the version. Also, HA releases are unrelated to Z-Wave JS versions. The only relation is when HA requires a minimum version. Otherwise, they are independent.
See here for the most common options, as it depends on how you’ve installed Z-Wave JS (add-on, container, self-installed, etc.):
https://zwave-js.github.io/which-version/
Given:
I would make a guess you are using the Z-Wave JS UI add-on. That is the latest version provided by that add-on.
